WiFi pods broken after Hub 4 replacement
knormington18
Hopefully someone can help please
I've had a new Hub4 delivered today and have now got access and such via WiFi
However....
I have 3 WiFi pods that do not work in anyway
They are constantly flashing light blue in colour and I cannot see them in the Virgin media connect app.
I've read something that the pods are "tagged" to the old router ? Is this correct as I suspect these haven't been migrated?
Any help would be massively appreciated
1 REPLY 1
They may not have been added to your account, if it doesn't happen overnight then call the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
