23-06-2023 09:56 - edited 23-06-2023 10:31
Hi, my pod has suddenly started flashing white and has disappeared from my Connect app.
I've unplugged and plugged back in near the router and plugged it back in its usual place and its now appearing on the Connect app but says pod offline and now flashing green.
Need replacing?
on 23-06-2023 19:23
Hi @ExxxyBeast
Welcome to the community forums
Sorry to hear that you're having issue with your WiFi pod
I have checked the systems at my side and can see that pod is connected, but your upstream power levels are quite high and out of specification. This would need an engineer visit to investigate further.
Please join me on private message so I can locate your account and pass account security. You can see your private messages at the top of the page, in the envelope icon or if you're using a smaller device, you can see your private messages by clicking on the Virgin Media logo at the top right and select 'Messages' from the drop down.
