on 23-10-2023 21:12
Been trying endlessly to get a WiFi pod for the office bedroom 7mb speed, app says good! Called the call centre and they said a button will appear in 24 hrs to order one. The app just takes you round in circles. I’m beginning to think these pods are a fairytale!
on 24-10-2023 08:42
Hi nickrix,
Thanks for your post and welcome back to the community.
Many apologies for the problems faced with getting a Pod ordered, so we can investigate this matter I've dropped you a PM.
The message will appear within the envelope icon.
Regards,
on 25-10-2023 08:42
Thanks for your cooperation over PM nickrix,
The Pod has now been ordered for you and should be with you within the next 2 - 3 working days,
If you do have any further queries then be sure to pop back up to the team for further assistance.
Take care,
