on 29-07-2023 14:11
Good afternoon
We are having problems with our landline. Incoming calls are cut off after a few rings, but ongoing calls seem to work OK.
Any thoughts?
on 29-07-2023 14:25
Hi teesvalley,
Thank you for reaching out to us in our community and welcome, sorry to hear you aree facing issues with incoming calls cutting out, is this happening with all calls or are they from the same Landline/ Mobile?
Paul.
on 29-07-2023 14:35
Seems to be all calls - landline and mobile
on 29-07-2023 14:39
Thank you for confirming this, have you checked our Service Status to see if there are any known area faults which may be causing this?
You can find more help and support around phoneline faults here.
Paul.
on 29-07-2023 14:45
Hi Paul
No issues flagged up & I've checked the socket etc. We've been hearing crackling on the line recently too. Could this be part of the same problem?
Tony
on 29-07-2023 14:51
Hi Tony,
Have you tried a different phone, if still using the old wall socket can you remove everything including any extensions, filter and try a different handset?
Paul.
on 29-07-2023 15:08
Hi Paul
Just checked with a corded phone and all is OK. Reconnected the cordless phone and that is OK too now. Weird!
Tony
on 29-07-2023 15:36
Hi Tony,
Thank you for trying a different handset, it is very strange it now works, please keep an eye on things and let us know how it goes.
Paul.
on 29-07-2023 15:43
Thanks Paul
Cheers
Tony
on 06-08-2023 13:02
We are now having problems receiving and making calls. Have done all the usual checks but no luck
Can you help?
Tony
