Dannyboydw's avatar
Dannyboydw
360 box help
Hi I got a new box installed and the old recordings and series links have came back on the box I can't delete them or watch recordings and it keeps asking to subscribe
  • Try using the TVGO app to delete the recordings, the recording info is held on Virgin's servers. You can also check the 360 box serial on the app is the same as the box you have, Settings, Info, About, will take you to your box serial number.
    What are you being asked to subscribe to, no image available at the moment.
  • Can I get a pm iam having issues with the box asing to subscribe and can't delete anything
    • roy247's avatar
      roy247
      Hero
      You will need to wait for the forum team to come back online for a pm, and it might be a few days before you get an answer.
      Sounds like a possible account issue and you may need to speak to Virgin.
      • Dannyboydw's avatar
        Dannyboydw
        I've spoke to them and it's like hitting a brick wall we need to send a engineer
        But the engineer dident have a scooby doo and came back the next day to swap the box
        And on the phone today going around in circles even the manager promised to call back dident
