Connection Failed - router reset doesn't work
Dunfield
Hi all, noob here.
I was setting up all my smart stuff since having my router upgraded to a hub5... logged into the router, and all of a sudden it booted me out and now none of my devices are able to connect to the WiFi!
I have reset the router twice, unable to log into the router, and no idea how to go about fixing this...
Add to that, I work from home and use a wifi connection, I'm concerned about connecting tomorrow morning! Any suggestions welcome.
1 REPLY 1
Did you do a pinhole reset like this....
_______________________________
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker so log in and change them back to what they were/want them to be.
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
