on 11-10-2022 08:56
Devices: Virgin Hub 3 and TP-LINK WPA4220
The power line Adapter works fine for Ethernet however the built in wifi range extender won't connect to the Hub 3.0 with WPS.
I know the WPS isn't faulty on the hub as the tv box was set up using WPS yesterday and I know the TP-LINK isn't faulty as it worked a couple of days ago at my old place.
Is this a known issue with TP-Link extenders or am I doing something wrong?
on 13-10-2022 11:26
Hi Dannyboy96,
Thank you for your post and welcome to our forums 🙂
I am sorry you are having issues with your power line adaptors have you tried the troubleshooting tips here.
Zoie
on 04-07-2023 08:50
Hi, I had a similar issue and this worked for me:
I followed the basic TP link instructions but it didn’t work with the Virgin Hub 3. So I went to the Virgin hub settings page:
Advanced Settings > Wireless > WPS
At the bottom it has a button to Add WPS Client. I pressed this while doing the TP link procedure and it worked.
Hope that helps someone!
on 04-07-2023 09:18
Don’t use WPS. Use the admin console on the TP-Link. It’s all in the manual and easy to do.
