Hive Hub won't connect to Internet
We had a Virgin broadband outage for most of Saturday, and since then the Hive hub wont connect to the Internet. We get a constantly flashing green light, which means it's trying to get an Internet connection.
Our internet connection is working though, generally 40mbs - yes it's slow but is quite normal for us.
I tried resetting the hub, via a paperclip, but this didnt make the Hive hub connect.
I have Virgin Hub3 in modem mode, connected to a TP-Link wireless mesh via an ethernet cable. The TP-Link network sees the Hive Hub.
Any ideas what Virgin changed during the broadband outage?
- I have the same problem - 2 weeks ago My internet went off and when It came back on my third party router has problems getting internet now . It's temperamental now - Some days the router works with the hub in modem mode some days like today it's not - I had to put the virgin hub back into normal mode today get the internet back on - At first I thought It was a problem with my router so i purchased another router but the same thing keeps happening ...... 3 routers I have at home now testing happens to all of them. keeps losing interent. - Strange thing is a couple of times the routers wifi will still work but the LAN ports will not .. - I'm using my Linkys ea9500 router connected to the hub in modem mode for years with no problem till couple weeks ago - Seems as if Virgin has changed something to not make my routers work propley anymore - I did phone Virgin last week and they said monitoring my connection ...then few days later had a text message saying it all looks fine but its not as my router stopped receiving internet again last night ..so I had to go back to the hub in normal mode for now for my wifi - But the thing is i need my 3rd party router as I have much better wifi coverage for my sercurity cameras ...these are off line now as virgin hub can't connect to them not good for coverage
