wheatleyroad's avatar
wheatleyroad
3 years ago
WiFi Pods - Ethernet Input for Backhaul
Hi folks,
I'd like to use the Virgin Wifi Pods to extend my Wifi network. I have ethernet access to my Hub 3 router in the areas where I would like to extend the weak Wifi network using the Virgin Wifi Pods.
The problem is that the Virgin Wifi Pod cannot seem to utilise the wired ethernet connection to the Hub 3 and is relying on relaying the weak Wifi connection from the Hub 3. In other words, the pods do not seem to allow Ethernet Backhaul. The pods are rebranded Plume devices and the Plume website specifically recommends an ethernet connection to the pods, "Does Plume support Ethernet Backhaul? Absolutely. Plume supports Ethernet backhaul. This means you can set up multiple gateway pods by connecting them directly together via Ethernet to deliver the fastest possible performance to your devices."
Virgin seem to have disabled this feature and only support output from the Wifi Pod's ethernet port. Does anyone know why this is and can it be changed? It would be great if we could encourage Virgin to unlock this feature. ðŸ¤ž
From reading on this forum, the Wifi Pod test group received pods with 2 ethernet ports that did offer Backhaul. However I have a single ethernet port pod as pictured below which would be so much more useful if Backhaul were enabled!
  • Hi Alex_RM and Adri_G ,
    Thanks for both of your help thus far. We have success! ðŸŽ‰
    Cabling was all ok. Channel Optimisation is switched ‘on’ already. It was Step 6 of Adri_G's post which solved it in the end. I have 2 pods, and I swapped the pods over. The second pod automatically connected by ethernet backhaul after about 5 mins. I now have full speed in the garden office from the pod which is connected to my Hub 3 by Cat6 ethernet cable. Great to have it working and I'm pleased that we could get a firm answer and result on this topic; The single ethernet port VM rebranded Plume pods do support ethernet backhaul. ðŸ‘Œ
    In response to your question Adri, it is the single ethernet port device as pictured in my first post.
    Alex_RM and Adri_G could you replace the faulty pod please? Happy to share my details in DM.
  • jhuk's avatar
    jhuk
    Trouble shooter
    That is why I edited my post and added the link. 😉
  • jhuk's avatar
    jhuk
    Trouble shooter
    Can you please take a photo of your BLACK POD and especially the sticker on the rear (hide your serial/mac address) as I want to see if VM have finally upgraded to Plumes WIFI 6 models for the HUB 5 users (Plume do WIFI 6E models also).
    NVM: Seem totally different, look more like a mini HUB.
    New black pods ? - Virgin Media Community - 5441499
  • So I got the Black WiFi Pod with two Ethernet ports on it, when I plug it in to the hub/switch it flashing green..
  • I have two Pods, both single port. Ethernet backhaul worked on mine (I only have one of them connected in that manner as it happens). The Pod that is connected via Ethernet isn't connected to the Hub directly either; it is connected via a small Netgear switch.
    I didn't need to make any config changes etc. for it to work.
  • Hi,
    I have also received the Black WiFi Pod with two Ethernet ports on it, when I plug in CAT6a cable into Pod down to the VM Hub 5, the white light on the pod starts flashing, surely thats not normal.. anyway to get this Backhaul enabled on the Pod?
    • legacy1's avatar
      No the port is only there because it was cheaper not to remove it and VM don't want to pay extra to enable it.
      • pankaj_65's avatar
        pankaj_65
        Really and you think Jeanie York from VM CTO would do this? Snice you seem to know the answer, do all us an favour and ask her???
  • I'd like to know this too.
    Our house has a thick brick wall separating the two halves. I have run an Ethernet cable from the Superhub to the other side of the house (through the wall). I was hoping that VM would be able to supply a WiFi Pod that had Ethernet backhaul capability as I could have connected it directly to this Ethernet cable and it would be the most efficient way of getting WiFi in the other side of the house.
    Over the last 3 weeks I have now been sent two of the single port WiFi pods (like the one you posted). Apparently these don't support Ethernet backhaul. On the second occasion I called them, VM support said they would supply a 2-port Pod, but alas only a single port one arrived.
    After speaking to VM support again today, they are now saying that the two port pods that do support Ethernet backhaul are not longer available (or supplied).
    I'm not sure what the truth is. The VM support agents don't really appear to know what I am talking about when I speak to them about the different Pod types.
    Does anyone know?
    • wheatleyroad's avatar
      wheatleyroad
      Does anyone know?
      I'm in the same boat jeremymorgan. I had read on another thread that VM Tech Support are able to unlock this feature for you remotely, will try and find the thread and link it here. I can't verify this myself, I imagine you'd have to get through to some pretty senior VM Tech Support to have someone able to do that for you. Be great to know if anyone has had this done? Or even better a response from VM saying they will unlock the Ethernet Backhaul feature! ðŸ’¡
        wheatleyroad
        Thanks for the pointer John. I understand that I could use an Access Point and in fact the Pod will be replacing an old Apple AP in that location. I was hoping to benefit from the Plume Pod's mesh networking and other more up to date features.
