be11aml's avatar
be11aml
2 months ago
Too Many Disconnections!
Back again, in desperation!
I've been having problems for months, but in the last few weeks it has become progressively worse. After an engineer visit new Hub 5 and (apparently!) a new connection at the cabinet, it has actually gotten worse.
I have requested an outdoor survey, as all the equipment in my house has recently been replaced and have another engineer visit provisionally booked for 22 December. However, I am now at the point where I will be requesting an early exit from my contract, as this really is unacceptable.
My previous request for help were not progressed as I was running my hub in modem mode, so I have now switched it back to router mode in the hope that some kind of diagnosis might be possible.
Here are my logs from less than 12 hours of uptime
System up time  0day(s)11h:14m:39s
Cable Modem Status
Item    Status    Type
Cable Modem Status    Online    DOCSIS 3.0
Primary downstream channel    Locked    SC-QAM
Channel Overview    Downstream    Upstream
DOCSIS 3.0 channels    31    5
DOCSIS 3.1 channels    1    1
3.0 Downstream channels
Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
1    163000000    7.5    43    QAM 256    4
2    155000000    8    42    QAM 256    3
3    171000000    7.3    43    QAM 256    5
4    179000000    7.2    43    QAM 256    6
5    187000000    7.1    43    QAM 256    7
6    195000000    7.3    43    QAM 256    8
7    203000000    6.9    43    QAM 256    9
8    211000000    6.8    43    QAM 256    10
9    219000000    6.4    43    QAM 256    11
10    227000000    6.2    42    QAM 256    12
11    235000000    6.2    42    QAM 256    13
12    243000000    6.1    43    QAM 256    14
13    251000000    5.8    43    QAM 256    15
14    259000000    5.8    43    QAM 256    16
15    267000000    5.4    43    QAM 256    17
16    275000000    5.3    42    QAM 256    18
17    283000000    5    42    QAM 256    19
18    291000000    4.9    42    QAM 256    20
19    299000000    5    42    QAM 256    21
20    307000000    5    42    QAM 256    22
21    315000000    4.7    42    QAM 256    23
22    323000000    4.7    42    QAM 256    24
23    331000000    4.4    42    QAM 256    25
24    339000000    4.6    42    QAM 256    26
25    347000000    4.6    42    QAM 256    27
26    355000000    4.4    42    QAM 256    28
27    363000000    4.5    42    QAM 256    29
28    371000000    4.6    42    QAM 256    30
29    379000000    4.3    42    QAM 256    31
30    387000000    4.4    43    QAM 256    32
31    395000000    4.3    42    QAM 256    33
Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
1    Locked    43    1305039    326305
2    Locked    42    447669    51730
3    Locked    43    1099552    1437186
4    Locked    43    1427030    1538202
5    Locked    43    830628    1408003
6    Locked    43    23039    45053
7    Locked    43    25310    49669
8    Locked    43    655    86
9    Locked    43    276    45
10    Locked    42    255    103
11    Locked    42    160    109
12    Locked    43    163    96
13    Locked    43    154    110
14    Locked    43    104    37
15    Locked    43    163    8
16    Locked    42    134    26
17    Locked    42    187    0
18    Locked    42    720    49
19    Locked    42    456    16
20    Locked    42    236    0
21    Locked    42    117    0
22    Locked    42    86    0
23    Locked    42    71    0
24    Locked    42    82    0
25    Locked    42    87    0
26    Locked    42    86    0
27    Locked    42    91    0
28    Locked    42    85    0
29    Locked    42    96    0
30    Locked    43    73    0
31    Locked    42    57    0
3.1 Downstream channels
Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
37    94    4K    1840    QAM 4096    1108
Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
37    Locked    0    3.0    212999039    0
  • be11aml's avatar
    be11aml
    General Configuration
    Network access
    Allowed
    Maximum Number of CPEs
    1
    Baseline Privacy
    Enabled
    DOCSIS Mode
    3.1
    Config file
    cmreg-vmdg660-bbt076-b.cm
    SFID
    237934
    Max Traffic Rate
    1230000450 bps
    Max Traffic Burst
    42600bytes
    Min Traffic Rate
    0 bps
    Primary Upstream Service Flow
    SFID
    237933
    Max Traffic Rate
    110000274 bps
    Max Traffic Burst
    42600bytes
    Min Traffic Rate
    0 bps
    Max Concatenated Burst
    42600bytes
    Scheduling Type
    Best Effort
    • Molly_T's avatar
      Molly_T
      Hi Be11aml 👋 Thanks for getting back to us and keeping the thread updated.
      Sorry to hear of your ongoing poor experience whilst trying to get this sorted! Hopefully your appointment today goes ahead without any further issues 🤞 - please let us know how you get on, and we can then offer further support if needed!
      Thanks for your continued patience. 🌞
  • be11aml's avatar
    be11aml
    3.0 Upstream channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    Symbol Rate (ksps)
    Modulation
    Channel ID
    0
    49600000
    39.8
    5120
    QAM 64
    1
    1
    43100000
    39.3
    5120
    QAM 64
    2
    2
    36600000
    38.8
    5120
    QAM 64
    3
    3
    30100000
    38.3
    5120
    QAM 64
    4
    4
    23600000
    37.3
    5120
    QAM 64
    5
    Channel
    Channel Type
    T1 Timeouts
    T2 Timeouts
    T3 Timeouts
    T4 Timeouts
    0
    ATDMA
    0
    2
    5
    0
    1
    ATDMA
    0
    2
    7
    0
    2
    ATDMA
    0
    2
    11
    0
    3
    ATDMA
    0
    2
    11
    0
    4
    ATDMA
    0
    2
    11
    0
    3.1 Upstream channels
    Channel
    Channel Width (MHz)
    Power (dBmV)
    FFT Type
    Modulation
    12
    10.4
    35.5
    2K
    QAM 256
    Channel
    Channel Type
    T3 Timeouts
    T4 Timeouts
    12
    OFDMA
    208
    74000000
    11
    0
  • be11aml's avatar
    be11aml
    Channel
    Frequency (Hz)
    Power (dBmV)
    SNR (dB)
    Modulation
    Channel ID
    1
    139000000
    10.1
    42
    QAM 256
    1
    2
    147000000
    9.7
    42
    QAM 256
    2
    3
    155000000
    9.2
    42
    QAM 256
    3
    4
    163000000
    8.9
    42
    QAM 256
    4
    5
    171000000
    8.7
    43
    QAM 256
    5
    6
    179000000
    8.7
    43
    QAM 256
    6
    7
    187000000
    8.4
    42
    QAM 256
    7
    8
    195000000
    8.5
    43
    QAM 256
    8
    9
    203000000
    8.1
    43
    QAM 256
    9
    10
    211000000
    8.1
    43
    QAM 256
    10
    11
    219000000
    7.8
    43
    QAM 256
    11
    12
    227000000
    7.7
    42
    QAM 256
    12
    13
    235000000
    7.4
    43
    QAM 256
    13
    14
    243000000
    7.4
    42
    QAM 256
    14
    15
    251000000
    7
    43
    QAM 256
    15
    16
    259000000
    6.9
    43
    QAM 256
    16
    17
    267000000
    6.7
    43
    QAM 256
    17
    18
    315000000
    5.8
    42
    QAM 256
    23
    19
    323000000
    5.7
    42
    QAM 256
    24
    20
    331000000
    5.6
    42
    QAM 256
    25
    21
    339000000
    5.8
    42
    QAM 256
    26
    22
    347000000
    5.6
    42
    QAM 256
    27
    23
    355000000
    5.6
    42
    QAM 256
    28
    24
    363000000
    5.4
    42
    QAM 256
    29
    25
    371000000
    5.5
    42
    QAM 256
    30
    26
    379000000
    5.5
    42
    QAM 256
    31
    27
    387000000
    5.5
    42
    QAM 256
    32
    28
    395000000
    5.4
    42
    QAM 256
    33
    29
    403000000
    5.3
    42
    QAM 256
    34
    30
    411000000
    5
    42
    QAM 256
    35
    31
    419000000
    4.9
    42
    QAM 256
    36
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    42
    1159
    2542
    2
    Locked
    42
    2833
    15320
    3
    Locked
    42
    3739
    19356
    4
    Locked
    42
    4271
    19021
    5
    Locked
    43
    4465
    18390
    6
    Locked
    43
    4044
    17328
    7
    Locked
    42
    4678
    19518
    8
    Locked
    43
    3929
    20255
    9
    Locked
    43
    4119
    19866
    10
    Locked
    43
    4535
    20567
    11
    Locked
    43
    4695
    17538
    12
    Locked
    42
    4632
    17100
    13
    Locked
    43
    4593
    18330
    14
    Locked
    42
    4707
    17872
    15
    Locked
    43
    4440
    19525
    16
    Locked
    43
    5408
    20130
    17
    Locked
    43
    4402
    11885
    18
    Locked
    42
    5499
    15063
    19
    Locked
    42
    6709
    15204
    20
    Locked
    42
    5749
    14607
    21
    Locked
    42
    6106
    19358
    22
    Locked
    42
    6140
    16106
    23
    Locked
    42
    6198
    16358
    24
    Locked
    42
    6671
    15830
    25
    Locked
    42
    7966
    10109
    26
    Locked
    42
    7026
    12654
    27
    Locked
    42
    6288
    10385
    28
    Locked
    42
    7499
    12564
    29
    Locked
    42
    6670
    15963
    30
    Locked
    42
    7423
    10235
    31
    Locked
    42
    7487
    7981
    Channel
    Channel Width (MHz)
    FFT Type
    37
    94
    4K
    1840
    QAM 4096
    1108
    Channel ID
    Locked Status
    RxMER Data (dB)
    PLC Power (dBmV)
    37
    Locked
    0
    4.2
    3778297925
    2574
  • be11aml's avatar
    be11aml
    Cable Modem Status
    ItemStatusType
    Cable Modem StatusOnlineDOCSIS 3.0
    Primary downstream channelLockedSC-QAM
    Channel OverviewDownstreamUpstream
    DOCSIS 3.0 channels315
    DOCSIS 3.1 channels11
  • Tudor's avatar
    Just from those stats it’s either a noise ingress on the low frequencies or a bad amp in the street cabinet, I suspect the latter. There is also a slim possibility that it’s a faulty hub. You definitely need a technician’s visit.
    • be11aml's avatar
      be11aml
      Thanks for the response. I've just had new hub 5 and while they all seem to be pretty poor, there is no difference in behaviour.
      I really think this is outside of my house - I'll give them this chance to fix it. My contract is up in March
      • Michael_M's avatar
        Michael_M
        Hello be11aml,
        Thanks for sharing that with us. Have you been able to book a technician appointment yet? The technician will discuss everything with you in person and check the external setup to make sure it’s sorted. We’re hopeful this visit will resolve the issue and get things running smoothly!
  • legacy1's avatar
    When in modem mode by a wired device ping -t 194.168.4.100 with BQM and check for Disconnections problem might not be hub or your router WAN but problem with your PC or wifi.
  • be11aml's avatar
    be11aml
    Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
    0    49600000    41.5    5120    QAM 64    1
    1    43100000    40.8    5120    QAM 64    2
    2    36600000    40.3    5120    QAM 64    3
    3    30100000    40    5120    QAM 64    4
    4    23600000    39.3    5120    QAM 64    5
    Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
    0    ATDMA    0    0    0    0
    1    ATDMA    0    0    0    1
    2    ATDMA    0    0    0    0
    3    ATDMA    0    0    0    0
    4    ATDMA    0    0    0    0
    Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
    12    10.4    37.2    2K    QAM 256
    Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
    12    OFDMA    208    74000000    7    0
    Network access    Allowed
    Maximum Number of CPEs    1
    Baseline Privacy    Enabled
    DOCSIS Mode    3.1
    Config file    cmreg-vmdg660-bbt076-b.cm
    SFID    236100
    Max Traffic Rate    1230000450 bps
    Max Traffic Burst    42600bytes
    Min Traffic Rate    0 bps
    SFID    236099
    Max Traffic Rate    110000274 bps
    Max Concatenated Burst    42600bytes
    Scheduling Type    Best Effort
    • be11aml's avatar
      be11aml
      Time    Priority    Description
      16-12-2025 08:22:19    notice    GUI Login Status - Login Success from LAN interface
      16-12-2025 05:16:50    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC[REMOVED]
      16-12-2025 04:50:44    notice    US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC[REMOVED]
      16-12-2025 03:15:01    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC[REMOVED]
      16-12-2025 03:09:39    notice    US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC[REMOVED]
      16-12-2025 03:06:19    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC[REMOVED]
      16-12-2025 03:04:36    notice    US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC[REMOVED]
      16-12-2025 02:02:29    warning    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC[REMOVED]
      15-12-2025 22:56:53    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC[REMOVED]
      15-12-2025 22:37:43    notice    US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC[REMOVED]
      15-12-2025 22:18:54    warning    MDD message timeout;CM-MAC[REMOVED]
      15-12-2025 22:18:33    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 3 4 5 6 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 22:18:23    warning    Dynamic Range Window violation
      15-12-2025 22:18:23    warning    RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC[REMOVED]
      15-12-2025 22:18:20    warning    MDD message timeout;CM-MAC[REMOVED]
      15-12-2025 22:18:01    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 3 4 5 6 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 22:10:53    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 3 4 5 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 22:10:35    notice    US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC[REMOVED]
      15-12-2025 22:02:44    critical    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC[REMOVED]
      15-12-2025 21:59:08    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 3 5 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 21:59:02    critical    Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC[REMOVED]
      15-12-2025 21:59:02    critical    16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC[REMOVED]
      15-12-2025 21:58:55    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC[REMOVED]
      15-12-2025 21:57:40    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC[REMOVED]
      15-12-2025 21:57:35    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 3 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=[REMOVED]
      15-12-2025 21:57:32    notice    CM-STATUS message sent. Event Type Code: 2; Chan ID: 3; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 21:55:37    notice    CM-STATUS message sent. Event Type Code: 5; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC[REMOVED]
      15-12-2025 21:55:13    notice    REGISTRATION COMPLETE - Waiting for Operational status
      15-12-2025 21:55:03    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC[REMOVED]
      15-12-2025 21:55:02    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC[REMOVED]
      15-12-2025 21:55:00    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC[REMOVED]
      15-12-2025 21:54:57    notice    Honoring MDD; IP provisioning mode = IPv4
      15-12-2025 21:54:46    warning    ToD request sent - No Response received;CM-MAC[REMOVED]
      15-12-2025 21:29:09    notice    GUI Login Status - Login Success from LAN interface
      15-12-2025 21:22:37    notice    GUI Login Status - Login Success from LAN interface
      15-12-2025 21:18:59    notice    GUI Login Status - Login Success from LAN interface
      [MOD EDIT: Private information removed]
