Nikospall's avatar
Nikospall
Hub 5x not showing connected devices
Hello,
I have recently joined VM and I was really pleased with the speeds and stability for a few months.
Suddenly, when I tried to use the VM app it asked me to join my 2 networks and when I cancelled it, I cannot see the hub in the app. I tried every troubleshooting method and I could not get it to work, VPN settings, reset, clear cache etc.
Seeing that the app is at least unreliable (rather euphemism) I decided to only use the hub's menu to check my network. Now the hub does not show ANY connected device at all. Apparently this is wrong as I am literally typing this being connected via the same hub but nothing shows up. Not Ethernet nor wireless. The networks can be detected, main and guest and all my devices are connected, as I am running a smart home setup on Home Assistant.
I am thinking of restarting the hub but I read that when other people tried it they lost or connectivity completely. As both I and my wife are working from home I am really reluctant to try this. Also my smart home has more than 30 devices relying on wireless connection, so fixing things can be a challenge.
Does anyone have previous experience on a similar issue?
Thank you
    There is no working modem mode for the Hub 5x at present.  It has been promised over the last many months, but is still not available.  Also good advice to dump the Connect app and manage the Hub via the admin console.
  • The hub started showing again the connected devices, I'll probably uninstall the app completely and not touch anything until the next time!
    I did not do anything at all, just started working out of the blue...
    It may take a full factory reset to get it working, and then don't use the app ever again ......
    If the Hub is power cycled or rebooted does that restore the functioning of the Connected devices screen ?
    • Nikospall's avatar
      Nikospall
      I'll bite the bullet and do it tonight, after my next meeting 😨
  • legacy1's avatar
    the hub 5x will be best used in modem mode due to unless support of router mode that VM don't fully support
      • legacy1's avatar
        I mean it in that VM should stop torturing us and give us modem mode for hub 5x🤕
    The VM Connect app may require your mobile to be on a connection to either the 2.4GHz or 5GHz bands of the main Wi-Fi service.
    With a split Wi-Fi I'd dump the Connect app ASAP as it will pester to re-merge or even proceed to re-merge onto a common SSID / Password which is not what you appear to prefer.
    Network scan apps are available for mobiles, can one of these see the connected devices ?
      Nikospall
      Yes, other scanners can see the devices, Fing finds everything both from mobile and Ethernet. It is certainly Hubx related. What I do not know is if the root cause is in the router or in the app (or both..)
