MattVahiboglu's avatar
MattVahiboglu
Hub 3 constant red light, but not hot
Hi, my Hub 3 is displaying a constant red light. The light turned red over a few hours and has been constantly red for 3 days.
The hub is standing in an open space with nothing covering it. The hub is not hot to touch. I have turned it off overnight but it came back on red.
I'm not getting anywhere with chat/whatsapp/phone. Based on similar forum posts and resolutions I believe I need an engineer to look at it, and possibly replace it.
  • For anyone else with this (seemingly common) problem: the engineer decided almost immediately to replace the hub.
  • Hey MattVahiboglu,  thank you for reaching out and I am sorry to hear about this red light issues.
    I am going to send you a DM but please do try these steps in the meanwhile;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
  • MattVahiboglu's avatar
    MattVahiboglu
