wabula
6 days agoJoining in
Critical error in Hub while in Modem Mode
Hub 5, set to modem mode.
Mesh connected and works perfectly for hours.
Sudden loss of wifi, unable to resolve until modem is turned off and on at wall.
This will repeat twice within a short time frame, then return to functioning.
The Hub has been replaced.
Attaching logs below
Timestamp | Level | Message |
02-09-2025 14:48:16 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1; |
02-09-2025 14:48:19 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1; |
02-09-2025 14:48:23 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1; |
02-09-2025 14:48:28 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:48:28 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;… |
02-09-2025 14:48:28 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;… |
02-09-2025 14:49:53 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;… |
02-09-2025 14:51:50 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
02-09-2025 14:51:52 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;… |
02-09-2025 14:52:15 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:52:16 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:52:32 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;… |
02-09-2025 14:52:33 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:52:34 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:52:34 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;… |
02-09-2025 14:53:17 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:53:41 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 14:54:29 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;… |
02-09-2025 14:54:29 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;… |
02-09-2025 14:54:29 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;… |
02-09-2025 15:05:46 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
02-09-2025 15:05:49 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;… |
02-09-2025 15:05:56 | notice | Honoring MDD; IP provisioning mode = IPv4 |
02-09-2025 15:05:59 | warning | DHCP WARNING - Non-critical field invalid in response;… |
02-09-2025 15:06:01 | notice | TLV-11 - unrecognized OID;… |
02-09-2025 15:06:05 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;… |
02-09-2025 15:06:14 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;… |
02-09-2025 15:06:19 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
