wabula's avatar
wabula
6 months ago
Critical error in Hub while in Modem Mode
Hub 5, set to modem mode.
Mesh connected and works perfectly for hours.
Sudden loss of wifi, unable to resolve until modem is turned off and on at wall.
This will repeat twice within a short time frame, then return to functioning.
The Hub has been replaced.
Attaching logs below
TimestampLevelMessage
02-09-2025 14:48:16criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1;
02-09-2025 14:48:19criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1;
02-09-2025 14:48:23criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ff:ce:fe:13:30;CMTS-MAC=00:01:5c:74:68:67;CM-QOS=1.1;CM-VER=3.1;
02-09-2025 14:48:28criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:48:28critical16 consecutive T3 timeouts while trying to range on upstream channel 2;…
02-09-2025 14:48:28criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;…
02-09-2025 14:49:53criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;…
02-09-2025 14:51:50criticalCable Modem Reboot because of - HW or Power-On Reset
02-09-2025 14:51:52criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;…
02-09-2025 14:52:15criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:52:16criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:52:32criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;…
02-09-2025 14:52:33criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:52:34criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:52:34criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;…
02-09-2025 14:53:17criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:53:41criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 14:54:29critical16 consecutive T3 timeouts while trying to range on upstream channel 0;…
02-09-2025 14:54:29criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;…
02-09-2025 14:54:29criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;…
02-09-2025 15:05:46criticalCable Modem Reboot because of - HW or Power-On Reset
02-09-2025 15:05:49criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;…
02-09-2025 15:05:56noticeHonoring MDD; IP provisioning mode = IPv4
02-09-2025 15:05:59warningDHCP WARNING - Non-critical field invalid in response;…
02-09-2025 15:06:01noticeTLV-11 - unrecognized OID;…
02-09-2025 15:06:05noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;…
02-09-2025 15:06:14warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;…
02-09-2025 15:06:19noticeREGISTRATION COMPLETE - Waiting for Operational status
  • Anonymous's avatar
    Anonymous
    Make sure your not using 2gb port
    Still lots of PostRS errors!  Until these are fixed there will be problems.  Usually indicative of noise on the circuit.
  • I am getting very little help from Virgin, regarding this.
    There only response has been to remove the mesh
      wabula wrote:
      Their only response has been to remove the mesh
      VM will not do any testing when you are using modem mode.  They will insist on Router mode.
    • Matthew_ML's avatar
      Matthew_ML
      Hey wabula, thank you for reaching out and we are sorry to hear you are not getting any support.
      We've taken a look at our side and the connection is looking okay.
      How does it test without the mesh?
