GCB100R's avatar
GCB100R
Just joined
7 months ago
Wired v Wireless uploads
Can anyone help identify what might be causing an issue with upload speeds over a wired connection.
I have the Gig1Volt service with a couple of wifi boosters running and a number of wired devices. At the hub I get 1148mbps download and 151 mbps upload. At the device (win laptop) using wireless I get 399mbps download and 107mbps upload, while wired I get 900mbps download but less than 2mbps upload.  This slow upload speed obviously causes issues.
Grateful for any suggestions.
  • Generally I have 3 or 4 ethernet connected devices and a dozen or so Wi-Fi (all on 5g Wi-Fi)
    • I think I have narrowed this down to an issue with the laptop (maybe a driver problem), rather than the network. using an alternative but similar laptop on the same network gave much better upload performance. Its a surface Pro laptop with a surface ethernet adapter, Wi-Fi Controller Intel (R) Wi-Fi 6 AX201 160Mhz (not sure if this is the info you needed?)
  • maxmarutti's avatar
    maxmarutti
    "At the device (win laptop) using wireless I get 399mbps download and 107mbps upload"
    399 Mbps download & 107 Mbps upload, are these maximum speed measurements ?
    Ideal conditions 2.4 GHz 802.11n Wi-Fi can support up to 300 Mbps for both download and upload speeds, depending on the router's capabilities. But older standard 802.11b may only achieve speeds of around 11 Mbps.
    However, real-world speeds may vary due to factors such as interference, distance from the router, and the number of devices connected to the network. It is also important to note that the 2.4 GHz band is more prone to interference from other devices, which can further reduce actual speeds.
    Ideal conditions, 5 GHz Wi-Fi can support much higher speeds compared to 2.4 GHz. For example, with the 802.11ac standard, 5 GHz Wi-Fi can theoretically reach speeds of up to 1.3 Gbps. With the newer 802.11ax (Wi-Fi 6) standard, even higher speeds are possible, with theoretical maximums of up to 9.6 Gbps / 9600 Mbps / 1.2 GBps 👀👀 In real-world throughputs ranging from 210 Mbps to 1 Gbps for 5 GHz networks, depending on the specific conditions and equipment used..
    "While wired I get 900mbps download but less than 2 Mbps upload"
    Can you tell me what LAN and Wi-Fi controller is in use on your laptop? How many devices are connected to 2.4 GHz & how many to 5 GHz?
    • GCB100R's avatar
      GCB100R
      Just joined
      Thanks, I've tried multiple speed tests and all have similar results.  I think I have narrowed this down to an issue with the laptop (maybe a driver problem), rather than the network. using an alternative laptop on the same network gave much better upload performance.
