  • 8
Therm0stat
remote control fault
Morning all,
The number 7 button has stopped working on my remote control. I've checked the batteries and believe the fault to be with the remote itself.
Can I just order another one online, or do I need to ring and book a fault with it?
thanks
  • 8.64K
  • 584
  • 1.71K
Re: remote control fault
you need to ring in and select the TV faults option
  • 8
Therm0stat
thanks.
I'll do that now.
Do they charge for a new remote?
  • 7.25K
  • 812
  • 3.05K
Free - provided it's fair wear and tear , which it is unless you or the dog have chewed on it!!
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
  • 8
Therm0stat
Thanks all,
I rang the support number and I now have a new and fully working remote.
  • 6.86K
  • 218
  • 511
Hi Therm0stat,
Thanks for your posts in the Forum and for getting back to us to let us know how you got on once you reported the fault with your remote control.
I'm glad to hear that our Faults Department was able to sort that out for you.
Please don't be a stranger around the Community. If there's anything we can help with, just drop us a line.
Take care.
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
