Dazzam8
TV signal keeps dropping in and out
Only just switched to virgin and this problem is really frustrating. The TV drops signal on and off constantly! Done all the usual stuff, reset/cable change/checked connections but still no luck.
I would like to get this fixed please
  • 982
  • 92
  • 189
LittleMick73
Well-informed
Re: TV signal keeps dropping in and out
Hi your best bet is to phone they can check your signal level while you're on the phone & if necessary send an engineer. Regards Micky
