  • 6
Kim84
Netflix help!
I ve recently joined virgin, and was told I'd get 6 months free Netflix how do I set that up? Do I need a code?
  • 8.64K
  • 584
  • 1.71K
Re: Netflix help!
Virgin should have emailed you a code, if you haven't had it you can phone in for it
Then go here to create your account https://www.netflix.com/gb the add your code here https://www.netflix.com/redeem?locale=en-GB
