Belle1
Missing remote. Cat 1- Remote 0
Help!
My bratty cat knocked my V box remote control inback of the wall radiator. There is no way I can reach it. Can I buy a new one from my local Virgin store?
Thanks.
Helpful Answers
  • 8.23K
  • 512
  • 2.26K
Re: Missing remote. Cat 1- Remote 0
Nope but if you phone in on 150, report a TV fault and and report it as broken by your cat they will sent you a shiny new one. Remote that is, not cat.
All Replies
  • 8.23K
  • 512
  • 2.26K
Belle1
Thanks. I just called them. They never asked me why I needed one, just asked if I had tried changing the batteries. I said yes. A new one will be with me within 7 days. I will keep this one away from my brat cat.
  • 2.75K
  • 45
  • 357
Buffer6
Trouble shooter
Have you tried poking a thin enough stick down the back of the radiator to release it?
