902110
Message 1 of 5
C130
Getting C130 messaged, saying Ethernet cable unplugged but not the case as working for every other wifi device...??
  • 477
  • 62
  • 137
backtothefuture
Fibre optic
Message 2 of 5
Re: C130
Is it only your WiFi devices that are working ? - Any that are connected by Ethernet cable are not working correctly ?
If I have helped please feel free to give 'Kudos' by clicking on the thumbs up icon against any of my posts. If I have helped to solve an issue you can also click on the 'Mark As Helpful Answer' link to mark it as helpful.
902110
Message 3 of 5
Re: C130
TiVo box not connected by Ethernet cable either, just a white wire. Everything on wifi...?
  • 477
  • 62
  • 137
backtothefuture
Fibre optic
Message 4 of 5
Re: C130
Is the 'C130' you mentioned what you are receiving on your TiVo box ?
If so someone from Virgin Media should be able to move your question to the TV section of the website and be able to assist you further.
  • 20.76K
  • 556
  • 3.22K
Sephiroth
Message 5 of 5
Re: C130
If you search the Community on the term 'C130' you'll see the various causes and resolutions.
