  • 5
Perks76
Message 1 of 5
V6 recording problem
I have a v6 box and a TiVo box. When setting a recording on my v6 box it records on my TiVo box and not my v6. How do I change my recording preferences ???
  • 17.83K
  • 1.67K
  • 3.13K
Message 2 of 5
Re: V6 recording problem
There is an drop down or other selector to ensure you're setting up the recording on the correct box.
Are you using the app or the website, and if you're using the app is it on a phone or tablet?
  • 5
Perks76
Message 3 of 5
No I'm using the v6 box in my living room, but it's recording on the TiVo in the bedroom. No app just using the box
  • 17.83K
  • 1.67K
  • 3.13K
Message 4 of 5
That's very strange.
There is no mechanism via the box itself to control Series Links on another TiVo or V6 box in the same house. Using the remote to set a recording should only do it on the box you're actually controlling at the time.
Especially if you're using the V6 remote as that should be set to RF mode which means it can't control the other TiVo box even if it was in the same room.
  • 5
Perks76
Message 5 of 5
Yeah this is what I don't understand. I shall try the reverse and record things on the other box and see if it records on the v6 box
