  • 203
  • 5
  • 17
fixerman
Superfast
Remote codes for av amplifiers?
Is it possible to programme the V6 remote to control the volume on an av Amp?
I have two setups one with a Yamaha amp and one with an oknyo amp.
Helpful Answers
  • 2.8K
  • 166
  • 374
ozsat
Trouble shooter
Re: Remote codes for av amplifiers?
Yes - it is all explained in the Help section on the main V6 menu - then select 'programming your remote'.
Previously I have found you need to set the tv first and then the amp - but they may now be fixed.
V6 TiVo (with MRS)
VIVID 350 Optical Fibre (350/20mb) in Area 31
SkyQ Silver Bundle (UHD + 2 minis)
All Replies
  • 2.8K
  • 166
  • 374
ozsat
Trouble shooter
V6 TiVo (with MRS)
  • 203
  • 5
  • 17
fixerman
Superfast
The instructions to " point the remote away from the Tivo" doesn't make sense because the new remote works without being pointed at the Tivo. Therefore any input on the remote results in the V6 responding and you lose the help screen.
  • 203
  • 5
  • 17
fixerman
Superfast
Please disregard my last post. I have succeeded by using the option to search all AV codes. It took a long time to find the Yamaha code but the Onkyo amp responded quite quickly.
All is happiness and light in the fixerman household now as the Camp Commandant can now use the new V6 remote for both V6 and AV amp without her having to use use two remotes.
Many thanks ozsat!
