Elcotto
Message 1 of 5
Box2box issue on TiVo V6 boxes
Just had 2 new v6 boxes installed and I love them.  I have just one issue I can't resolve and that is using the box2box. It keeps throwing up the error that it can't connect to lounge box.  I have power lines installed with the help of the engineer that are both working perfectly fine ( I have tested them both with 2 other devices)
i have rebooted my superhub 2 and the power line adapters with no success.  Is it possible that they drop the connection when they go into power Saving stand by mode. Could other devices ( iPads, iPhones or Xbox one ) be interfering with them. They have connected a couple of times briefly. Please help......
  • 11.68K
  • 1.11K
  • 2.41K
Message 2 of 5
Re: Box2box issue on TiVo V6 boxes
Can you confirm which software level you are on as the latest level, which has started being pushed out, does have a power setting which does disable MRS access (and TV Anywhere access).
Go to your power savings settings and see if you have Eco Low Power and Connected Low Power settings. The former disables MRS.
Elcotto
Message 3 of 5
Hi Ernie
I have 3 powers saving settings
always on (no power saving)
snooze (suggestions on)
snooze (suggestions off) - this is the one that is ticked
thanks
  • 1.34K
  • 101
  • 245
stevedh2
Knows their stuff
Message 4 of 5
Not updated then, or you could look in settings/system info/system info and see what the version is.
the old version number was
20.5.8.RC12-VMB-11-C68.
and the new on (as far as I can tell as I havn't been updated yet) is
20.5.8.1.RC4-VMB-11-C68
Elcotto
Message 5 of 5
Yep just checked - still on the old one
