laura5
Just joined
help
I need virgin to contact me ASAP how can I get them to do this.
  • 1.58K
  • 101
  • 270
Re: help
Ringing them on 789 using your mobile is the quickest way to get in contact. If your handset isn't working, you can use 0345 6000 789 - which should be free if you're calling from another mobile with inclusive minutes.
If you don't want to be the one initiating the communication, you'd need to supply your contact details somehow. You can't do that on a public forum, so the only way is for you to contact VM I'm afraid.
Good luck.
