  • 5
Frankaston
Upgrade help please!
Currently coming to the end of a Virgin VIP mobile package. Unlimited calls, texts and data about £25 per month. Have to upgrade apparently. Use quite a lot of data. Like my present handset. (a) Can I retain the handset and go for a SIM only deal? (b) Do Virgin do this? (c)How does it work? (d) Will I just be sent a new SIM card for insertion into my phone? This mobile ludite would be very appreciative of any advice available.
  • 3.83K
  • 901
  • 1.7K
Re: Upgrade help please!
Hi Frankaston,
you don't have to upgrade. If you are happy with your present handset, stick with it Smiley Happy
If you want to change your tariff to one of the new SIM only deals you can. Call the Team (free) on 789 from your handset to discuss this.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
