Finchy70
Swap mobile numbers
I have 2 mobiles with virgin on different tarrifs. Can I swap over the phone numbers?
  • 13.73K
  • 563
  • 964
Re: Swap mobile numbers
Hi Finchy70
Thanks for getting in touch, unfortunately it's not possible to swap the numbers around on the tarrifs. Depending on how the account is set up and the handsets you're using, there's a small possibility we can swap the phone packages around.
To double check, give our team a call on 150 from any Virgin line or 0345 6000 789 from any other.
I hope this helps!
