skyperr
Message 1 of 7
Roaming in Ireland and the cost of receiving calls
I live in Ireland and travel to the UK frequently. I need a UK mobile number that I can receive calls with back home in Ireland that has either low or no charges for receiving incoming (roaming) calls. I'm thinking of getting a Virgin PAYG phone and I would like to confirm what charges apply for receiving incoming (roaming calls). The information available suggests that these are free, but I want to confirm this in advance before proceeding.
Helpful Answers
  • 3.84K
  • 902
  • 1.7K
Message 2 of 7
Re: Roaming in Ireland and the cost of receiving calls
Hi skyperr,
according to the coverage & costs page HERE it is indeed free to receive a call in Ireland Smiley Happy
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
All Replies
  • 3.84K
  • 902
  • 1.7K
Message 2 of 7
Hi skyperr,
AlexKid :-)
skyperr
Message 3 of 7
Thanks indeed for that. Are Virgin PAYG sim cards available from any large retailers?
  • 3.84K
  • 902
  • 1.7K
Message 4 of 7
Hi skyperr,
I would say so. They are certainly available in my local Tesco and Asda.
Even my local corner shop sells a selection of SIM's from various networks.
AlexKid :-)
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 5 of 7
Three Mobile UK - No roaming charges between Irish Republic and UK
Don't know if the same deal goes for Three Ireland
skyperr
Message 6 of 7
3 UK will only work on 3 Ireland as part of their "3 Like Home" tariffs if you have PAYG with one of their packages which start from around £20 a month. If you just use straightforward PAYG (the £1 SIM card) and just top up are normal, you don't get the benefit of 3 Like Home. They are not clear about this and I only found out by chance when I queried it in a 3 store.
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 7 of 7
My Three PAYG works on 'At Home'. Used it in France and Spain quite recently. I paid 99p for the SIM and as I use Wifi to make many of my calls, I top up around £5 per month.
You can't use it permanently in an At Home country as it is meant for tourists, but it is the only one I know where you won't get clobbered by Roaming charges.
End of June next year all roaming charges are abolished in the EU. (One more reason to stay in!)
https://www.three.co.uk/Support/Free_SIM/Order Read the last couple of lines
