paulesdale
Phone connection abroad
I am in Lanzarote and cannot make calls. How do I link to a network provider?
  • 3.84K
  • 902
  • 1.7K
Re: Phone connection abroad
Hi paulesdale,
did you check that roaming was set up on your mobile account before leaving the UK?
Try going into the phone's settings and do a manual search for network.
(Also check that roaming is enabled on the handset itself).
Here is a help page from Virgin: Using your mobile abroad
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
