  • 39
angelis76
Message 1 of 10
Phone Problems
Does anyone know if the phones come with a warranty? I've had my phone for 5 months but it keeps going quite hot and the battery drains quickly as in less than a day when it's not being used as I'm in work, can't be coping for another 19 months with that
  • 8
AcecorePotter
Message 2 of 10
Re: Phone Problems
Hi angelis76
Sorry to hear you are having trouble with your device.
Depending on your model you will indeed have a warranty that lasts between 1 and 2 years.
You can get some help troubleshooting these problems using our Phone Fix pages. This will guide you through step by step checks and will advise you how to try and resolve the issues.
Hope this helps!
Liam
I work for Virgin Mobile but my views and opinions are my own. Virgin Media are not responsible for my comments.
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Message 3 of 10
Re: Phone Problems
Hi Angelis76 Smiley Happy
Thank you fro your time and welcome back Smiley Happy
It's great to see some help here and I would like to know if you have been able to look inot the page? I would like to ask if you're seeing this phone overheat when on charge?
Many thanks.
Ben
  • 39
angelis76
Message 4 of 10
Re: Phone Problems
No it's not when it's on charge. It doesn't happen all the time but when it does happen the battery seems to drain quickly too
  • 4.95K
  • 146
  • 282
Message 5 of 10
Re: Phone Problems
Hi Angelis76,
Thanks for the reply Smiley Happy
The battery overheating can be a result of the processor resources being quite high, usually due to an app or gps being used at the time. Battery heavy apps can be a result of this and just to be safe, are you able to backup your data and information and perform a factory reset of the phone?
Finally, can you tell me what device you currently have?
Many thanks and take care.
Ben
  • 39
angelis76
Message 6 of 10
Re: Phone Problems
I am just trying to download updates now for itunes so I can back the phone up. I have an Iphone 5S
  • 4.95K
  • 146
  • 282
Message 7 of 10
Re: Phone Problems
Cheers Angelis76 Smiley Happy
I hope to hear from you soon and thank you for coming in.
If you need any help on safely backing up your data for your device, just let me know Smiley Happy
Take care.
Ben
  • 39
angelis76
Message 8 of 10
Re: Phone Problems
Probably a stupid question, but how do I know that my phone is definitely backed up?
  • 39
angelis76
Message 9 of 10
Re: Phone Problems
Ok I am having trouble restoring factory settings, itunes starts it but an hour later the progress bar has not moved
  • 6.86K
  • 218
  • 511
Message 10 of 10
Re: Phone Problems
Hi angelis76,
Thanks for getting back to us. Has everything reset on your mobile now?
If you need further help with running a factory reset on your handset, please have a look at our Mobile Help pages: Phone Support
Kind regards,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
