gillsmith205
Network registration problem
When I try to 'phone out I'm getting a message saying "not registered on network". How do I get back on to the network?
  • 3.83K
  • 901
  • 1.7K
Re: Network registration problem
really need a little more info' first but:
Assuming your phone with the SIM in it was used recently (I.e, it's not been disconnected due to being inactive).
Have you tried the obvious such as turning off & on again so that it should search for network. Or try removing the battery whilst the phone is on then reinstall it & turn the phone back on which will re-boot it.
Can you go into settings & manually select a network?
AlexKid :-)
  • 4.89K
  • 216
  • 441
Hi gillsmith205,
Welcome to the community and thanks for posting. I deeply apologise for the troubles you've had when dialling out. I'll happily provide assistance to get to the bottom of this.
I need more information to try and establish what the problem is. Could you please answer the following questions:-
Does your phone have a signal when you're calling?
Are you able to send/receive text messages?
What are the first 3 digits of the number you're trying to call? (Don't post whole number)
Hope to hear from you soon.
Rich
gillsmith205
Hi Alex, Thanks for replying - it was a simple tun off and on again solution. I'm not at all tecky and panic if anything goes wrong. Thanks for your help its good to be back in action!
Gill
  • 3.83K
  • 901
  • 1.7K
Hi Gill,
pleased to hear that it was such a simple solution Smiley Happy
Happy to help
AlexKid :-)
_____________________________________________________________________
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
gillsmith205
sorted now thanks.
