  • 8
ChicaGuacamole
Network/Signal Issues
I was wondering if there is any way of checking for network issues - both my mum and I have been having problems on our mobiles this evening. Signal appears so come and go, and we never usually have any issues with this at all. Aberdeen area. VM on Twitter have not responded, and obviously we can't phone as the signal is being very tempramental!
Thanks in advance!
Helpful Answers
  • 2.94K
  • 377
  • 929
Re: Network/Signal Issues
You could try putting your post code into the EE network status checker:
http://ee.co.uk/ee-and-me/network/4gee/network-status-checker
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out so my answers may be wrong :-) If you do like my answer please mark it as helpful as it may help others
All Replies
  • 2.94K
  • 377
  • 929
Scott
  • 8
ChicaGuacamole
^^Thanks very much, looks like there is a problem in the area that should be fixed within 3 days. Hopefully it doesn't take too long!
Thanks again Smiley Happy
  • 3.81K
  • 894
  • 1.7K
Hi ChicaGuacamole,
for an up to date answer, you would be best to give Virgin mobile customer services a call on 789 from your Virgin mobile if you have a signal
Or 0345 6000 789 from any other phone.
They would be able to advise if there are any known faults or maintenance being carried out in your area which could be affecting you and hopefully a timescale for completion if this is the case.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
