ELLEN2
Just joined
I NEED TO GET A PAC CODE FOR MY NUMBER
I HAVE NO SERVICE, NEED TO GET A PAC CODE FOR A NUMBER I HAVEN'T USED FOR 1 YEAR.
  • 16.66K
  • 1.39K
  • 3.41K
Re: I NEED TO GET A PAC CODE FOR MY NUMBER
hiya @ELLEN2 typing in caps is considered shouting in a forum, to get the PAC code would need to have a chat with virgin mobile customer services via 789 from virgin mobile or 0345 6000 789 http://store.virginmedia.com/discover/mobile/switch/how-to.html using online chat via http://contact.virginmedia.com (using PC/laptop), since the PAC request cant be issued via the forum community due to issues of Data Protection.
also if you haven't used the number in awhile number might be non-transferable
