simonsays
How to tell if iphone 5s is using 4G?
I put a new 4G SIM in my Iphone 5s and selected the LTE option.  How do I tell if the phone is actually working on LTE/4G, as it still just shows 3G icon on menu, and sometimes just E.  What should it display if use LTE?  I am using ios 9.
  • 17.82K
  • 1.67K
  • 3.13K
Re: How to tell if iphone 5s is using 4G?
You should see either 4G or LTE shown where you currently see 3G or E
4G services won't start until the first available refresh date after you made the change to the 4G tariff, even if you've put your new 4G SIM in before that.
simonsays
It should have refreshed by now, and am on a 4G plan, and the data allowance is being used up, so why would it not be displaying LTE or 4G?  It is an iphone 5s with ios 9.3.2  And I have selected LTE in the mobile data settings.
  • 17.82K
  • 1.67K
  • 3.13K
Just to double check - when is your normal billing / refresh date and when did you order the new 4G tariff?
