Ellieclarke1989
Just joined
How do I block a number
Have an alba smart phone brought from Argos I neednto block a number from calling and texting me. How do I do it been through all the setting in my phone and see no option to block
Tags (1)
  • 3.82K
  • 896
  • 1.7K
Re: How do I block a number
Hi Ellieclarke1989,
if your phone doesn't come with the ability to block calls you could always add one.
I downloaded a free app from the Play Store called "Calls Blacklist"
(there are others but I find this simple and effective).
I hope it works for you Smiley Happy
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 1.58K
  • 101
  • 270
Select the number in your call log and press the button that brings up the menu. On my phone it's "MORE" up at the top right, but it might be just three dots or a hard button at the bottom of the screen. There should be a "block this number" option.
I feel your pain. The manual is so basic it doesn't even tell you how to make a call, let alone block a caller...
