SonyXperia
Help with blanked out 'transfer to SD card'
Can anyone help me sort blanked out 'transfer to SD card' on my Sony Xperia Aqua 4. Don't want to do complete restore again. Same happened 2 months ago and 2nd new SanDisk micro memory card....heeeelllllppp?
  • 108
  • 6
  • 35
geoff1962
Up to speed
Re: Help with blanked out 'transfer to SD card'
Hi. Which apps are you trying to transfer. Not all apps can be transferred to sd card
SonyXperia
Hi Geoff, thanks for getting back but I've now sorted it by installing 'File Commander' app. I had to delete some music/podcasts to make room for it but I'm up and running again and the 'blanked out' button on the 'move to SD card' notification is now working fine too.
The app is great and I just manually moved all my music and a few apps to my memory card...sorted! Yaaay
I hope this will help others
  • 108
  • 6
  • 35
geoff1962
Up to speed
Glad you've got it sorted
