Star-kitty
Just joined
Help!! Precious memories needs to be saved before repairs will delete.
Hello everyone.  I need help.  I'm about to send my phone off for repairs, and I'm supposed to back everything up, mainly photos and videos, or they'll be lost.  Can anybody suggest a way to do this as my phone is a complete blank screen.  Using a cloud service or an sd card won't work if I can't use the screen.  Thanks
  • 3.82K
  • 897
  • 1.7K
Re: Help!! Precious memories needs to be saved before repairs will delete.
Hi Star-kitty,
if your phone will power on (even though the screen may remain blank) connect it to a PC or laptop using a USB cable.
You will then be able to access and save all your photos and videos.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 9
andrewall
a couple of assumptions here.....its an android phone and you have a google account set up......you may have told the phone (or it may have been set up anyway) to sync your files and photos to a google account.....check google photos/google drive through your laptop to see if they're there
