  • 31
sengaaaa
Going abroad
My family and I are going to Spain ina couple of days. Just looking to confirm that we don’t have to do anything to our 4 contract mobiles or buy data packs before we go.
We should be able to get off the plane and use our contracts as normal?
Cheers
  • 2.75K
  • 310
  • 742
teabag
Trouble shooter
Re: Going abroad
Before you go away help page
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
Ring 789 (1>4>1) from each mobile before you go and go through the automated check that roaming is setup ok for each SIM, if a problem is found it will automatically connect you to someone who will assist.
You can also so log into each online account, check roaming is turned ON and International call barring is turned OFF.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
  • 31
sengaaaa
Re: Going abroad
Cheers T 👍🏻
