  • 5
Slomoejoe1
Message 1 of 5
Galaxy s6 edge nougat
Hi, can anyone tell me when will galaxy s6 edge get nougat update
Helpful Answers
  • 17.64K
  • 1.64K
  • 3.07K
Message 2 of 5
Re: Galaxy s6 edge nougat
See the thread here were it's been discussed http://community.virginmedia.com/t5/Virgin-Mobile/Android-7-on-S6/td-p/3366870
All Replies
  • 17.64K
  • 1.64K
  • 3.07K
Message 2 of 5
  • 46
ryan282
Dialled in
Message 3 of 5
is there any news on the nougat update for the s6
would i void my warranty if i used odin to put nougat on my s6?
and which version should i use?
thanks in advance for any help/advice
  • 1.73K
  • 221
  • 432
enlli
Super solver
Message 4 of 5
If you use Odin correctly all the warranty indicators stay in place as before.
The version marked BTU  seems to be the one.
  • 17.64K
  • 1.64K
  • 3.07K
Message 5 of 5
If you do do a manual update is that depnding on the firmware is that Virgin Media show up as EE.
It might have changed, but not all of the firmwares used to have the code to recognise Virgin Media as it's own network.
