Madden_90
Message 1 of 5
Rewind and Recorded programmes problem
Watching live tv is not problem but, No matter what channel or programme it is, Wether it is paused/rewound or watched as a recording. I will get constant glitches where my box freezes and I lose a good couple of minutes about every ten. Has this happened to anybody else? Driving me insane! Thank you
  • 8.39K
  • 534
  • 2.32K
Message 2 of 5
Re: Rewind and Recorded programmes problem
Sounds like your HD is on the way out...
Are there any other symptoms? Clicking noise form the TiVo for example?
Madden_90
Message 3 of 5
Not that I've noticed. Like I say watching live tv is perfect on any channel. As soon as you watch something recorded you end up losing half the programme!
  • 8.39K
  • 534
  • 2.32K
Message 4 of 5
Take a punt on 150 from your VM landline or wait for staff to pick it up on here.
Either way I think you may need your TiVo swapped out, but staff should be able to tell you better.
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Message 5 of 5
Hi Madden_90,
Thank you for posting, welcome into the Community Smiley Happy
I am sorry to read that you have experienced some interruptions on the TV services in the home. After having a look at the connection and running some tests, it's clear to see that there are some issues that would need to be looked at and adjusted by and engineer. Your hard drive is showing some errors that would indicate a problem with the hardware and would be contributing to your issues.
If you can have a little look inside your Inbox, you'll see I've sent you a Private Message. You can find this at the top right of the page, purple envelope.
Speak to you soon and welcome into the Community.
Ben
