johnbhoy1967
Message 1 of 5
upgraded today. 50mb to 200mbs. How long does it take to kick in?
hi
just upgraded today and been doing speedtests but so far i can see no difference.   internet has gone on and off a couple of times.  is this normal?
  • 21.65K
  • 781
  • 3.1K
Message 2 of 5
Re: upgraded today. 50mb to 200mbs. How long does it take to kick in?
how do you connect. Wireless or wired? The internet going off shouldn't happen
johnbhoy1967
Message 3 of 5
i am connecting on wifi.  only getting 25mb.   tried via ethernet and only getting 35mb.
  • 9
g182
Message 4 of 5
I did the same today - By the end of the call my package was activated according to the tech I spoke to.
Router status page also shows link speed increase but performance is worse than before.
  • 7.36K
  • 314
  • 523
Message 5 of 5
Hi johnbhoy1967,
Welcome to the Community!
Sorry to hear you're having trouble with your connection.
I've located your account and I can see your 200Mbps package has been activated. I can also see an issue with the network in your area affecting speeds at peak times - Ref.(F004877090). Our technicians are working to get this sorted and have set a review date of 15th March 2017.
I've run a diagnostic on the equipment and picked up an issue with your upstream power levels, too. This will need to be adjusted by one of our technicians. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Look forward to hearing from you! Smiley Very Happy
Josh
