slowrouternov17
slow internet speed
Hello,
I have the VIVID 100 Optical Fibre, which should enable speeds of up to 100Mbps but it's barely getting past 5mbps and it's very slow. Also says telephone line is disabled? not sure why as everything seems fine, phone still rings when called
Please see downstream, upstream and network log below:
Downstream bonded channelsChannel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
12990000003.728.6256 qam13
2323000000429.2256 qam16
33150000003.528.7256 qam15
43070000003.728.7256 qam14
52910000003.228.4256 qam12
62830000003.228.2256 qam11
7275000000328.4256 qam10
82670000002.928256 qam9
92590000002.728.1256 qam8
102510000001.927.6256 qam7
112430000001.527.3256 qam6
122350000001.527.6256 qam5
132270000001.727.3256 qam4
142190000001.727.4256 qam3
15211000000227.8256 qam2
162030000001.927.4256 qam1
Upstream bonded channelsChannel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
231000000ATDMA47.264 qam64000005120
137600000ATDMA47.264 qam64000005120
Network LogDate And Time Error Number Event Description
2017-11-11 13:07:02.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 13:07:19.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 01:35:04.0084020100Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 01:35:19.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:24:41.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:24:41.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:24:44.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:40:09.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:51:27.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 19:51:27.0068010600DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-11 21:27:20.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-12 04:55:26.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-12 12:37:13.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-12 21:35:15.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-13 12:57:54.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-13 13:32:05.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-14 14:51:06.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-11-14 18:37:07.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 9.36K
  • 800
  • 1.96K
Re: slow internet speed
Your downstream SNR is too low and VM need to take a closer look.
You will need to contact VM for resolution, either by waiting here about a week until a VM Forum Team Member picks up the thread, or give them a call on 150 from a VM line or 0345 454 1111 for a quicker response.
  • 8.35K
  • 362
  • 589
Hi slowrouternov17,
Welcome to the Community!
I'm sorry to hear you're having trouble with your connection.
I've run diagnostics on your equipment and your levels seem to be okay at the moment. How has it been since posting? Are you still getting slow speeds?
Speak soon
Josh
