  • 23
TrafficProducer
keep changing to Slow speed
After reset router is goes at correct speed but next day it have changed to slow speedKeeps chaging speeds to slow.jpg
  • 5.45K
  • 201
  • 324
Re: keep changing to Slow speed
Hello TrafficProducer,
Welcome to the community.
I have located your account and your signals are looking okay at the moment so can I just check whether you're using a wired or wireless connection?
Looking forward to hearing from you
Rose
  • 23
TrafficProducer
Wires cable Lan to Desktop from router
  • 10.82K
  • 308
  • 631
Hi TrafficProducer,
Thanks for getting back to us.
I've taken a look at your connection, the line is showing as fine. There are no faults reported and the network segment is running stable.
Do you still have to re-boot the router to get the speeds back to normal?
Have you tried another device to see if you get the same speeds?
Hope to hear from you soon
Sam
