  • 75
  • 13
jra505
Vivid 200 slower than Vivid 100
Hello,
I live in area (HP3)  which has been plagued with a utilization issue for years, and it has finally been fixed - my 100mbps service is now consistently at that level. Given that the problems appear to have been sorted, I thought I would try "upgrading" to the 200mbps service. What a mistake!
Since moving to the "faster" service, my speed has gone down!
How on earth can this be? I know they are going to say "its UPTO 200mbps", but surely the UPTO 200mbps should be faster than the UPTO 100mbps service? Otherwise, why pay the extra money just to get a slower speed? For the odd occasion that the speed is a little bit faster?
HMMMMPPPH!
  • 10.58K
  • 311
  • 653
Re: Vivid 200 slower than Vivid 100
Hello jra505,
Sorry to hear about the slow speeds you're getting, I know it's disappointing after upgrading.
What averages are you getting when you perform speed tests with an Ethernet cable? Does peak time make any difference to your results?
Please get back to us so we can continue to investigate.
Take care.
Heather_J
  • 75
  • 13
jra505
Hello
On average, during busy times, the 200 mbps service is 30 mbps slower than the 100 mbps service. That is because the 100mbps service is actually achieving 100mbps, whereas the 200mbps service is only achieving 70mbps.
Surely, the 200mbps should be at least as fast as the 100mbps service? Not slower.
This was measured using an ethernet connection.
jra505
  • 10.82K
  • 308
  • 632
Hi jra505,
Thanks for getting back to us.
I appreciate this must be frustrating and apologies for the inconvenience caused.
The test you completed through Ethernet, was that direct to your router or direct to the Hub? If so, are you able to try whilst the Hub is in modem mode please? As this will eliminate other devices connected?
If you are using your own router, has it got any QoS settings that need to be changed by any chance?
Is the PC/laptop you are using got a gigabit LAN card and are you using a Cat 5e or above Ethernet cable?
Speak soon
Sam
  • 75
  • 13
jra505
As it happens, it does now seem to be OK- I think the issue was with the speedtesting website I was using (http://testmy.net/auto). When I use www.speedtest.net I do apparently achieve 200mbps.
Do you have a recommended way of testing speed?
jra505
  • 10.58K
  • 311
  • 653
Hey there jra505,
Thanks for the update Smiley Happy
Good to hear that you've tested a much better speed now, we also advise using speedtest.net as it's reliable.
Thanks again for keeping us in the picture, let us know if there's anything else we can help with.
Take care.
Heather_J
