watsondesign
Upgraded to 300/350mb... strange issues
Hi all.
First of all, when I log into my account in the VM portal it says VIVID 350 Optical Fibre. Which to me implys that I am on the 350mb package and not the 300 one, am I correct? It seems everyone (and there has been multiple calls) that I have spoken to on the phone tells me that a 350mb package does not exist. I even had an engineer out last friday to check the line and he told me 300mb is the top package, but it seems others on here have different information?
I've recently upgraded to 300mb from the 200mb package. At 200mb my connection was very stable and always returned around 220mb down 10 up on a wired connection on the speedtest.net website.
However..
Since upgrading to 300, I am only getting around 140mb down as a final result on speedtest.net, during the test it seems to push over 200mb but then settle down and end up around 100. I've tried a couple of other websites and they seem to get much higher figures of around 300mb as expected.
It seems that many others are getting higher figures on speedtest.net on here so is there an issue with my connection?
I have called the techincal line a few times now, one said she had changed the frequency of the line, a different one told me there was issues with my line and she would have to call someone out to check it. A nice chap turned up last friday and fitted a -10db adapter to the line, which didnt seem to do much, told me it was fixed and left.
So just to double check, would anyone be able to have a look through my router config to see if everything is ok?
Log below:
status:
Acquired Downstream Channel(Hz)
595000000
Locked
Ranged Upstream Channel(Hz)
53700000
Locked
Provisioning State
Online
Downstream:
Downstream bonded channelsChannel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
15950000001.438.6256 qam24
25870000001.938.9256 qam23
35790000001.538.6256 qam22
4571000000138.6256 qam21
55630000001.738.9256 qam20
65550000001.938.9256 qam19
75470000002.240.3256 qam18
85390000002.238.9256 qam17
95310000001.738.9256 qam16
105230000001.738.9256 qam15
11515000000138.9256 qam14
125070000001.238.9256 qam13
134990000002.238.9256 qam12
144910000002.438.6256 qam11
15483000000238.9256 qam10
164750000002.540.3256 qam9
174670000002.238.9256 qam8
18459000000240.3256 qam7
194510000002.738.9256 qam6
204430000002.738.9256 qam5
214350000002.238.9256 qam4
224270000002.538.9256 qam3
234190000002.438.9256 qam2
244110000002.238.9256 qam1
Upstream:
Upstream bonded channelsChannel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
453700000ATDMA42.364 qam64000005120
327400000ATDMA42.364 qam64000005120
Configuration:
Operational ConfigurationGeneral Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u-b.cm
SFID780256
Max Traffic Rate402500000
Primary Upstream Service Flow
SFID780255
Max Traffic Rate22010000
Network Log:
Network LogDate And Time Error Number Event Description
2018-02-02 13:42:38.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:42:38.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:42:44.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:06.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:06.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:07.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:07.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:12.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:53:17.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:57:21.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:57:21.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:57:22.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:57:26.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 13:57:41.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-02 20:16:40.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-02-05 16:27:45.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thank you!
  • 333
  • 39
  • 146
Andruser
Fibre optic
Re: Upgraded to 300/350mb... strange issues
Can't help on most of that, but regarding the 300 or 350 question, Virginmedia's marketing is all about big round numbers, so they've got 50, 100, 200 and 300 Mbps packages.  Anybody on older packages (say 150 Mbps) stays on that, but change anything and you have to choose one of the new standards.
However, for reasons that I suspect come down to the number of channels and frequencies, the maximum speed that you'll get (always in the best case, so you could get lower) is actually a bit higher than all of those round numbers.  My Turgid 200 connection has just given a Speedtest result of 227.3 Mbps.  So I would not be at all surprised if a 300 connection was returning 340-360 speeds, and people assume that there is a 350 Mbps?
Of course, that's no comfort for those with ropey connections or over-subscription constraints, and even having a 227 Mbps connection doesn't delight me in the way that a 100 Mbps connection with consistent low latency would.  But whilst Verminmedia's persist with the crap Hub 3, the latency issue won't be resolved.
  • 6.88K
  • 182
  • 454
Sorry to hear about this watsondesign,
I'd like to look into this for you.
To allow me to do so, could you respond via private message with the following information?:
  • Please can you confirm your name and if you are the account holder?
  • Home address
Nat_J
  • 451
  • 16
  • 48
ILuvNips
Fibre optic
Looking at the config files it does suggest 350 down and 16 up?
________________________________________________________________
In HA7. Billing Area 21.
Utilisation Fault
F003502423: Review Dates -> 07/10/2015 -> 02/12/2015 -> 20/01/2016 Smiley Sad -> Closed Smiley Happy
Utilisation Fault F004873444: Review Dates -> 29/03/2017 Smiley Sad -> Closed Smiley Happy
Utilisation Fault F005506920: Start Date -> 09/08/2017 Smiley Sad -> Open Smiley Sad
  • 6.88K
  • 182
  • 454
Thanks for getting back to me, Smiley Happy
I've located your account info and everything appears to be performing as expected at the moment.
Are you mainly having trouble with a hardwired or wireless connection?
Speak soon,
Nat_J
watsondesign
It seems to be fine on every speed test except speedtest.net which I find strange. Can you also confirm if I am on the 300 or 350mb package?
