  • 18
BlueDot
Super Hub 3 won't work with switch or router
I need more ethernet ports than Super Hub 3 can supply. However, when I attach a Netgear 8-port ethernet switch it doesn't work. The computers on the switch does not get regconised by the Super Hub. VM support is washing their hands of the problem, claiming that since connecting to the SH3 works they don't care that a switch won't work. So, one last try before I also wash my hands off VM and go to BT, does anyone have any ideas on how to get the switch to work ? p.s. Ethernet over powerline doesn't work either with this hub.
Thanks.
  • 18
BlueDot
Re: Super Hub 3 won't work with switch or router
Sorry, this message seems to have gone to the wrong section. Can a mod please delete it ?
