  • 6
Macbeth
Message 1 of 10
Speed update
Hi all new member so having to learn.  My problem is I received an email from Virgin saying my speed has been updated to 70 megs over a week ago but still only getting 55 megs.
Helpful Answers
  • 9.48K
  • 650
  • 1.81K
Message 4 of 10
Re: Speed update
log into superhub - 192.168.0.1 - DON'T SIGN IN, click router status  - and post the downstream and upstream figures and the config
again are you testing wired or wireless
____________________
Tony
  • 9.48K
  • 650
  • 1.81K
Message 7 of 10
Re: Speed update
levels are good and regardless you are still on 50meg - thats shown in the config file
onfig File
SFID 385340
Max Traffic Rate 57600000 bps
thats 50meg
you need to give retentions a ring - they should be able to sort it - should all happen whilst you are on the phone to them
dial 150 or 0345 454 1111 and follow the prompts to - you are thinking of leaving us - dont worry about that they do much more - open 'till 8pm - 6pm on saturdays - closed sunday and the plus is its a UK call centre
Tony
  • 10.02K
  • 294
  • 625
Message 9 of 10
Re: Speed update
Hey Jeff,
Hope you're well Smiley Very Happy
Thanks for your post, I can see you've had great support from Tony.
I've just checked your connection and I can see that you're now subscribed to the 70Mb package. What speeds are you getting when you perform a test now?
If you need anything else, please just ask.
Catch you soon,
Take care.
Heather_J
All Replies
  • 9.48K
  • 650
  • 1.81K
Message 2 of 10
Re: Speed update
what device are you testing with
have you rebooted the SH - turn it off and back on - leave it off a couple of minutes
post the config - see if that says 55 or 70
Tony
  • 6
Macbeth
Message 3 of 10
Re: Speed update
Hi Tony switched off for approx 19 mins and rechecked down;load speed still showing 55 megs please could you let me know where to find configs as took speed test from ookla.
Regards Jeff
  • 9.48K
  • 650
  • 1.81K
Message 4 of 10
Re: Speed update
Tony
  • 6
Macbeth
Message 5 of 10
Re: Speed update
Hi I tony I hope these will help;
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 299000000 267000000 275000000 283000000 291000000 307000000 315000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 17 13 14 15 16 18 19 20
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 6.90 6.94 6.96 6.54 6.81 6.66 6.48 6.35
RxMER (dB) 38.26 37.94 37.94 37.64 38.26 38.26 38.26 38.26
Pre RS Errors Reset Counter 56266 37065 11702 28069 704 386 395 376
Post RS Errors Reset Counter 305 286 273 290 298 286 285 270
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 38 N/A N/A 40
Frequency (Hz) 39400000 N/A N/A 25800000
Ranging Status Success Other Other Success
Modulation 64QAM N/A N/A 64QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 44.00 N/A N/A 42.25
General Configuration
Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
SFID 385340
Max Traffic Burst 10000 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow
SFID 385339
Max Traffic Rate 3250000 bps
Max Traffic Burst 8160 bytes
Max Concatenated Burst 8160 bytes
Scheduling Type Best Effort
  • 6
Macbeth
Message 6 of 10
Re: Speed update
Hi Tony I forgot to say it is a wired
Yours Jeff
Ps apologise for being all over the place.
  • 9.48K
  • 650
  • 1.81K
Message 7 of 10
Re: Speed update
onfig File
SFID 385340
thats 50meg
Tony
  • 6
Macbeth
Message 8 of 10
Re: Speed update
Hi Tony
Thank you for your speedy help, I will give them a ring tomorrow.
Yours Jeff
  • 10.02K
  • 294
  • 625
Message 9 of 10
Re: Speed update
Hey Jeff,
Catch you soon,
Take care.
Heather_J
  • 6
Macbeth
Message 10 of 10
Re: Speed update
Sorry it has taken so long to reply and thank you for all your help I am now getting 70 plus megs, thank you.
Jeff
