  • 5
RunnerBubbsy
Message 1 of 8
Slow broadband 200 MB Package
Slow broadband
Has anyone got any tips on how to speed up Virgin broadband?  I have a 200MB package, however even with a direct connection to the Router I struggle to get more than 50 MB download speed.
I've tried rebooting my PC and also the Virgin box, however no improvement.
Any ideas?
Helpful Answers
  • 2.96K
  • 378
  • 939
Message 2 of 8
Re: Slow broadband 200 MB Package
Is the direct connection with a PC/Mac that has a gigabit Ethernet port and is the Ethernet cable cat 5e or higher?
How are you testing the speed, are you using http://www.speedtest.net/ or just downloading from a web server?
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
If you go to http://192.168.100.1/ to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take up to a week) and run checks on your line.
______________________
Scott
All Replies
  • 2.96K
  • 378
  • 939
Message 2 of 8
Scott
  • 5
RunnerBubbsy
Message 3 of 8
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)290750000234750000242750000250750000258750000266750000274750000282750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID3225262728293031
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)0.860.760.790.780.800.831.060.84
RxMER (dB)37.0936.8437.0937.0937.9437.0937.0936.84
Pre RS Errors1821226636263632814024833227101782217038
Post RS Errors20121809162914481638277121162709
  • 5
RunnerBubbsy
Message 4 of 8
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID9N/AN/A11
Frequency (Hz)46200000N/AN/A32600000
Ranging StatusSuccessOtherOtherSuccess
Modulation16QAMN/AN/A16QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)46.00N/AN/A46.21
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 5
RunnerBubbsy
Message 5 of 8
First TimeLast TimePriorityError NumberDescription
17/11/2016 13:13:22 GMT17/11/2016 13:13:22 GMTError (4)68010302DHCP WAN IP - xxxxxxx
17/11/2016 13:12:33 GMT17/11/2016 13:12:33 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
16/11/2016 11:02:48 GMT16/11/2016 11:02:48 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
16/11/2016 11:02:47 GMT16/11/2016 11:02:47 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
16/11/2016 09:18:42 GMT16/11/2016 09:18:42 GMTWarning (5)84020200Lost MDD Timeout
16/11/2016 09:18:41 GMT16/11/2016 09:18:41 GMTWarning (5)84020200Lost MDD Timeout
16/11/2016 09:18:37 GMT16/11/2016 09:18:37 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
14/11/2016 10:34:12 GMT14/11/2016 10:34:12 GMTError (4)68010302DHCP WAN IP - xxxxxxxxxx
14/11/2016 10:33:41 GMT14/11/2016 10:33:41 GMTError (4)68000407TOD established
14/11/2016 10:33:31 GMT14/11/2016 10:33:31 GMTCritical (3)82000200No Ranging Response received - T3 time-out
14/11/2016 10:33:24 GMT14/11/2016 10:33:24 GMTNotice (6)84000510Downstream Locked Successfully
14/11/2016 10:32:48 GMT14/11/2016 10:32:48 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
  • 5
RunnerBubbsy
Message 6 of 8
Speed is generally no more than 50 MB the whole day .. connected with a Laptop with a gigabit Ethernet port using a 5e cable.  Testing using Speed Net .. also tried connecting via WiFi on iPhone 6 and still never more than 50 Mb download
  • 2.96K
  • 378
  • 939
Message 7 of 8
Power levels all look OK.  The sync and timeout errors in the log are not normal and hopefully the forum team can shine some light on the reason for those errors when they get to this thread in a few days.
Sorry I couldn't be of more help.
Scott
  • 10.82K
  • 308
  • 631
Message 8 of 8
Hiya RunnerBubbsy,
Thanks for posting and a warm welcome to the community.
My apologies that you are not achieving the up to 200 Mbps broadband speeds.
I've taken a look at your connection, the line and hub have come back as fine. The network segment is running stable and healthy which is good.
With the MDD time-outs that Scott mentioned, there was an SNR fault in your area at the time you posted which could of caused these. Has there been anymore since?
Have you tried a speed test whilst the Hub 3 is in modem mode at all? If so were the results any different?
Let us know how you get on
Sam
