  • 42
manzir95
Message 1 of 31
Ping spikes and intermittent youtube buffering issue
Got virgin media recently and im getting alot of ping spikes when i try and ping any website the ping is really inconsistent for example i was pinging google earlier on and i was getting something like 21ms, 90ms, 32ms, 20ms and was wondering what would be the best fix for that
Another issue iv got is with youtube sometimes when i play a video it buffers for a few seconds which i find really unusual, was with bt previously and never had the buffering bar come up even once during my 2 years with them, is this like a bug with youtube or is it the ping spikes causing it?
  • 11
SparkyKarl
Message 2 of 31
Re: Ping spikes and intermittent youtube buffering issue
Virgin Media Broadband currently has issues with over-utilization. I'd check around the forum to see if your area is not affect. This is an on-going issue across the country, keep it in mind.
  • 1.34K
  • 102
  • 247
stevedh2
Knows their stuff
Message 3 of 31
Is it like this all the time, or just at certain times of the day?
Are you connecting wired or via WiFi, if via WiFi, do you get the same problems wired.
probably worth setting up a BQM http://www.thinkbroadband.com/ping/monitors.html
Also probably worth connecting to 192.168.0.1 clicking on check router status and posting the results here just incase something has happened to your levels.
  • 42
manzir95
Message 4 of 31
Tbh I don't think I have over utilisation problem in my area because I get 52-54mb on a 50 mb package at all times Including peak times but who knows
  • 42
manzir95
Message 5 of 31
Iv actually tried bqm but can't get it working it's filled with a red bar and when it comes to ping spikes I'd say it's all the time, since iv got Virgin media iv never noticed a stable ping
And it's wireless can't get it wired cuz the router is like downstairs but the connection is definitely stable, had my bt router in the exact position and always got stable ping and speed
  • 1.72K
  • 155
  • 463
Message 6 of 31
If you have the SH3, you have to turn the firewall off for the BQM to work.
Doesn't matter if the VM hub is in the same place, it's a different bit of kit, not all routers are made equal. It's always best to test things wired, this will show whether it's just a wireless problem or something else.
  • 42
manzir95
Message 7 of 31
I'll try it out and get back to you
  • 42
manzir95
Message 8 of 31
So far this is what I'm getting on bqm does it look orite? http://www.thinkbroadband.com/ping/share/054006911c25d8d11ddf385b44c57615-19-02-2017.html
  • 42
manzir95
Message 9 of 31
  • 42
manzir95
Message 10 of 31
Is this normal?
