pagsey
New HUB 3.0 terrible connection!
After connection and speed trouble in the past week the helpdesk booked an engineer to come out and swap out the SuperHub 2 router for a new HUB 3.0. The engineer was brief and said that the power db was too high and fitted a 3db and 10db attenuators.
But nothing improved, in fact if possible it has got worse! Speed test is hit and miss sometime 20MB but most less than 10MB and more often less than 1MB with lots of disconnects. Nowhere near the 70MB advertised number.
I have now set the HUB 3.0 into modem mode and dug out my Fritz box and at least I have some stability now. But the speed issue remains.
I have given up with the helpdesk!
BQM
http://www.thinkbroadband.com/ping/share/8ee90a600553e991dbedcf6568278394-14-01-2017.html
HUB 3.0 settings
Cable Modem Status Item Status Comments
Acquired Downstream Channel(Hz)
323000000
Locked
Ranged Upstream Channel(Hz)
31000000
Locked
Provisioning State
Online
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
13230000003.736.3256 qam16
2315000000436.3256 qam15
33070000003.936.3256 qam14
4299000000436.3256 qam13
52910000003.936.3256 qam12
62830000003.936.6256 qam11
72750000003.736.3256 qam10
8267000000436.6256 qam9
9259000000436.3256 qam8
10251000000437.3256 qam7
112430000004.136.3256 qam6
122350000004.137.3256 qam5
13227000000437.3256 qam4
14219000000437.3256 qam3
15211000000437.6256 qam2
16203000000437.3256 qam1
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
531000000ATDMA52.564 qam64000005120
437600000ATDMA52.564 qam64000005120
Operational Configuration General Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
cxv9873254k;fg87dsf
SFID1924
Max Traffic Rate77000000
Primary Upstream Service Flow
SFID1923
Max Traffic Rate5250000
Help please!!
  • 10.02K
  • 332
  • 877
Hero
Re: New HUB 3.0 terrible connection!
You likely don't need the 3db just the 10db attenuator would likely be enough.
The hub 3 has its problem and may not be fixed any time soon.
pagsey
Thanks for the quick reply Legacy1. I removed the 3db attenuator and power is up to 6.6dbmV with 36.6 SNR.
Do you have any details about the HUB 3.0 problem? (I'm guessing its firmware!?)
  • 10.02K
  • 332
  • 877
Hero
Not that I said needed to remove it...so are the upstream power levers lower now?
more about the hub 3
https://community.virginmedia.com/t5/Gaming-Support/Hub-3-Compal-CH7465-LG-TG2492LG-and-CGNV4-Latenc...
