  • 139
  • 38
gringopig
Up to speed
Message 1 of 96
Low Download speeds Edinburgh EH3. Utilisation issues?
I'm getting terrible speeds in the evening lately:
Is this a high utilisation issue in my area and if so, when can I expect a fix?
Hardly acceptable for a 152Mb/s connection.
Thanks.
  • 139
  • 38
gringopig
Up to speed
Message 2 of 96
Re: Low Download speeds Edinburgh EH3. Utilisation issues?
Very clearly a utilisation issue. The speed this same evening 23:40
After a phone call to technical support, a very helpful technician advised me that there were no known issues in my area.
I think there is clearly and would appreciate a timetable for resolution of this problem and a fault reference number.
Thanks.
  • 13.02K
  • 372
  • 1.06K
Moderator
Moderator
Message 3 of 96
Hi gringopig,
Thanks for posting and sorry for the slow speed problems, I've run a few checks on your connection and reports indicate (as you may have already guessed) that your network segment is currently suffering from spikes of high utilisation, particularly at peak times.
I've raised to our network teams for further investigation into the best ways to mitigate the load.
Please check back in with us periodically and we will update you as soon as we have any further information.
Ralph_R
Forum Moderator
  • 139
  • 38
gringopig
Up to speed
Message 4 of 96
Thanks for the reply.
I do hope you sort this out as I don't fancy paying for a degrading service in the long term.
  • 13.02K
  • 372
  • 1.06K
Moderator
Moderator
Message 5 of 96
Hi gringopig,
Just to let you know that the networks reference is F003292364 with upgrades currently scheduled for December to help remedy the capacity problems.
Apologies again for the impaired service.
Ralph_R
Forum Moderator
  • 139
  • 38
gringopig
Up to speed
Message 6 of 96
OK thanks. Getting really poor speeds tonight, so I do hope it gets better soon.
Cheers for info.
  • 61
partitura
Dialled in
Message 7 of 96
It is the same in EH11 and has been for about a month or so. Everything slows to a crawl between 9pm and 11pm. Otherwise it is fine.
  • 14.39K
  • 640
  • 1.45K
Moderator
Moderator
Message 8 of 96
Hi Partitura,
I've checked your connection and while there is no utilisation fault open there is a spike in utilisation at about 9 until 11 as you describe. This isn't for long enough to raise yet but I've asked for this to be monitored so we can raise it as soon as possible.
  • 61
partitura
Dialled in
Message 9 of 96
It is a daily occurrence and has been since late July.
  • 139
  • 38
gringopig
Up to speed
Message 10 of 96
Well. I'm looking about for alternative deals at the moment personally and noticed that at last BT Fibre has been enabled in EH3, so there is actual competition now and if it stays like this:
then I will be leaving. Check the 68ms ping to the South Gyle!
I get lower pings to Europe than my home town.
BT Infinity is a strong competitor and I would rather sacrifice a slice off the top of this 152Mb/s service in exchange for stability and guaranteed speeds.
